 Re: 12bits ADconv MAX128 vervolg Kategorie: Programmierung Basic (von Hans - 2.10.2006 22:12)
 Als Antwort auf Re: 12bits ADconv MAX128 vervolg von H.J.W. - 2.10.2006 19:14
Hans nutzt:  CC1-M-Unit V1.2/2.0
Thanks
The connection is a sensor   4 - 20 mA
so I have 1 to 5 volt or 1 to 4,095 volt      4095
Im testing with 1,2volt op each Ad in
What can the problem be ???
Hans
> Hello,
> If I’m correct then you have a device (NTC or PTC or…..) connected between the +16V connection and Channel connection?
> If you have nothing connected then the result will be “0”.
> Greetings,
> H.J.W.
Re: 12bits ADconv MAX128 vervolg (von H.J.W. - 2.10.2006 22:46)
