 Re: symbole auf lcd Kategorie: C-Control I V1.2/2.0 (von H.J.W. - 12.10.2006 23:23)
 Als Antwort auf symbole auf lcd von chuckie - 8.10.2006 21:09
Hello,
I wrote this CCBasic example for the C-Control I v2.02 with Applicationboard 2.0.
It will NOT work on the C-Control I V2.01.
Greetings,
H.J.W.
'*                    WINDT SYSTEMS                   *'
'* LCD Possibilities v1.6 for CCIUM2.02 with CCIAB2.0 *'
'*                  2006 / H.J.WINDT                  *'
'This software, with the C-Control I Unit M2.02 mounted on the C-Control I Application Board 2.0,'
'shows the possibilities of the APPLICATION BOARD LCD that are not supported in ccbasic2.0.'
'The possibilities include: reverse printing, 3 different cursors, cursor shifting,
'user defined characters and display on/ off.'
'User defined characters is the possibility to design your own 8 characters.'
'Feel free to use and share this software'
'**************** I/O PORTS ****************'
'-----port 2 lcd connections-----'
define lcd_port byteport[2]
define db4 port[9]  'databus 4'
define db5 port[10] 'databus 5'
define db6 port[11] 'databus 6'
define db7 port[12] 'databus 7'
define rw port[13] '0 = write to lcd display / 1 = read from lcd display'
define rs port[14] '0 = command / 1 = data'
define en port[15] '1 to 0 = enable'
define lcd_light_off port[16] '(off)0 = light on / (on)1 = light off'
'**************** A/D PORTS ****************'
'**************** D/A PORTS ****************'
'**************** VARIABLES ****************'
define lcd_busy bit[1]
define adr byte[2] 'lcd address code'
define cmd byte[3] 'lcd command code'
define dat byte[4] 'lcd data code'
define loop byte[6]
'**************** CONSTANTS ****************'
'****************** SETUP ******************'
gosub initialize_lcd
beep 4,2,4: beep 4,2,4
'***************** PROGRAM *****************'
lcd_light_off = 0
#start
print"#ON_LCD#";
print"#CLR#"; 'forward and reverse printing on lcd'
gosub entry_mode_set_left_to_right 'print from left to right'
print"#L101#";
print"Entry Mode LR";
gosub entry_mode_set_right_to_left 'print from right to left'
print"#L216#";
print"Entry Mode RL";
pause 200
for loop = 0 to 3 'no cursor and 3 different cursors'
print"#CLR#";
print"Cursor ";loop;" ";
on loop gosub lcd_cursor_0, lcd_cursor_1, lcd_cursor_2, lcd_cursor_3
pause 200
next
print"#CLR#";
print"Cursor Movement"; 'moving the cursor left and right'
for loop = 1 to 15
pause 25
gosub lcd_cursor_shift_left 'shift the cursor left'
next
for loop = 1 to 15
pause 25
gosub lcd_cursor_shift_right 'shift the cursor right'
next
pause 25
gosub lcd_cursor_0
print"#CLR#";
print"Generated Chara."; 'printing 4 example generated characters on the lcd'
print"#L205#";
put&h08                  'antenna'
print" ";
put&h09                  'heart'
print" ";
put&h0a                  'happy'
print" ";
put&h0b                  'window'
pause 200
print"#CLR#";
print"    DiSpLaY     ";  'display off on off on ......'
print"#L201#";
print"     ON/OFF     ";
for loop = 1 to 10
pause 25
gosub display_off
pause 25
gosub display_on_0
next
print"#OFF#";
tog lcd_light_off
goto start
'*************** SUBROUTINES ***************'
#display_off                         'lcd display OFF/ cursor OFF / understripe OFF'
cmd = &b00001000:goto command_to_lcd
#display_on_0                        'lcd display ON and'
#lcd_cursor_0                        'cursor OFF / understripe OFF'
cmd = &b00001100:goto command_to_lcd
#display_on_1                        'lcd display ON and'
#lcd_cursor_1                        'cursor BLINKS / understripe BLINKS'
cmd = &b00001101:goto command_to_lcd
#display_on_2                        'lcd display ON and'
#lcd_cursor_2                        'cursor OFF / understripe ON'
cmd = &b00001110:goto command_to_lcd
#display_on_3                        'lcd display ON and'
#lcd_cursor_3                        'cursor BLINKS / understripe ON'
cmd = &b00001111:goto command_to_lcd
#lcd_cursor_shift_left               'shifts cursor left without clearing character'
cmd = &b00010000:goto command_to_lcd
#lcd_cursor_shift_right              'shifts cursor right without clearing character'
cmd = &b00010100:goto command_to_lcd
#entry_mode_set_left_to_right 'sets printing to left to right ex. HELLO'
cmd = &b00000110
goto command_to_lcd
#entry_mode_set_right_to_left 'sets printing to right to left (backwards) ex. OLLEH'
cmd = &b00000100
goto command_to_lcd
#command_to_lcd
gosub busy_flag_check_from_lcd
deact db7:deact db6:deact db5:deact db4
lcd_port = (lcd_light_off * 128) or (cmd / 16) : pulse en 'HIGH NIBBLE command to lcd'
lcd_port = (lcd_light_off * 128) or (cmd mod 16) : pulse en 'LOW NIBBLE command to lcd'
return
#data_to_DD_ram_lcd
cmd = &b10000000 or adr : gosub command_to_lcd
goto put_data_into_lcd
#data_to_CG_ram_lcd
cmd = &b01000000 or adr : gosub command_to_lcd
#put_data_into_lcd
lcd_port = &b00100000 or (lcd_light_off * 128) or (dat / 16) : pulse en 'HIGH NIBBLE data to lcd'
lcd_port = &b00100000 or (lcd_light_off * 128) or (dat mod 16) : pulse en 'LOW NIBBLE data to lcd'
return
#data_from_DD_ram_lcd
goto get_data_from_lcd
#data_from_CG_ram_lcd
#get_data_from_lcd
deact db7 : deact db6 : deact db5 : deact db4:rw = 1:rs =1 : en = 1
dat = 0
dat = (abs(db7) * 128) or (abs(db6) * 64) or (abs(db5) * 32) or (abs(db4) * 16) 'HIGH NIBBLE data from lcd'
pulse en
dat = dat or (abs(db7) * 8) or (abs(db6) * 4) or (abs(db5) * 2) or (abs(db4) * 1) 'LOW NIBBLE data from lcd'
en = 0
goto command_to_lcd
#busy_flag_check_from_lcd
deact db7 : deact db6 : deact db5 : deact db4:rw = 1:rs = 0:en = 1
lcd_busy = db7
pulse en
if lcd_busy then goto busy_flag_check_from_lcd
return
'******* INITIALIZATION SUBROUTINES ********'
#initialize_lcd
print"#ON_LCD#";"#INIT#";"#CLR#";"#OFF#";  'initialize lcd display'
#character_build 'generates characters in lcd ram from characterbuild table / 8 characters of 5 x 8 pixels'
for adr = 0 to 63                'lcd display character generation (CG) address'
looktab characterbuild, adr, dat 'lcd data for character generation'
gosub data_to_CG_ram_lcd         'set character generation data in CG address'
next
return
'********* CALIBRATION SUBROUTINES *********'
'****************** DATA *******************'
'                 (CG    dat     adr) 000/XXXXX  first 3 bits are not used/ last 5 bits are for character generation   '
table characterbuild &b00010001 '(0)  000/1   1' character build data for antenna symbol/ read from DD-ram address &h08'
                     &b00011111 '(1)  000/11111'                                                           *use put&h08*'
                     &b00010101 '(2)  000/1 1 1'
                     &b00000100 '(3)  000/  1  '
                     &b00000100 '(4)  000/  1  '
                     &b00000100 '(5)  000/  1  '
                     &b00000100 '(6)  000/  1  '
                     &b00000000 '(7)  000/     '-----------------------------------------'
                     &b00000000 '(8)  000/     ' character build data for heart/ read from DD-ram address &h09'
                     &b00000000 '(9)  000/     '                                                  *use put&h09*'
                     &b00001010 '(10) 000/ 1 1 '
                     &b00011111 '(11) 000/11111'
                     &b00001110 '(12) 000/ 111 '
                     &b00000100 '(13) 000/  1  '
                     &b00000000 '(14) 000/     '
                     &b00000000 '(15) 000/     '-----------------------------------------'
                     &b00000000 '(16) 000/     ' character build data for happy/ read from DD-ram address &h0a'
                     &b00000000 '(17) 000/     '                                                  *use put&h0a*'
                     &b00001010 '(18) 000/ 1 1 '
                     &b00000000 '(19) 000/     '
                     &b00000100 '(20) 000/  1  '
                     &b00010001 '(21) 000/1   1'
                     &b00001110 '(22) 000/ 111 '
                     &b00000000 '(23) 000/     '-----------------------------------------'
                     &b00011111 '(24) 000/11111 character build data for window/ read from DD-ram address &h0b'
                     &b00010101 '(25) 000/1 1 1'                                                  *use put&h0b*'
                     &b00010101 '(26) 000/1 1 1'
                     &b00011111 '(27) 000/11111'
                     &b00010101 '(28) 000/1 1 1'
                     &b00010101 '(29) 000/1 1 1'
                     &b00011111 '(30) 000/11111'
                     &b00011111 '(31) 000/11111'-----------------------------------------'
                     &b00000000 '(32) 000/00000 empty place for character build data/ read from DD-ram address &h0c'
                     &b00000000 '(33) 000/00000'                                                       *use put&h0c*'
                     &b00000000 '(34) 000/00000'
                     &b00000000 '(35) 000/00000'
                     &b00000000 '(36) 000/00000'
                     &b00000000 '(37) 000/00000'
                     &b00000000 '(38) 000/00000'
                     &b00000000 '(39) 000/00000 -----------------------------------------'
                     &b00000000 '(40) 000/00000 empty place for character build data/ read from DD-ram address &h0d'
                     &b00000000 '(41) 000/00000'                                                       *use put&h0d*'
                     &b00000000 '(42) 000/00000'
                     &b00000000 '(43) 000/00000'
                     &b00000000 '(44) 000/00000'
                     &b00000000 '(45) 000/00000'
                     &b00000000 '(46) 000/00000'
                     &b00000000 '(47) 000/00000 -----------------------------------------'
                     &b00000000 '(48) 000/00000 empty place for character build data/ read from DD-ram address &h0e'
                     &b00000000 '(49) 000/00000'                                                       *use put&h0e*'
                     &b00000000 '(50) 000/00000'
                     &b00000000 '(51) 000/00000'
                     &b00000000 '(52) 000/00000'
                     &b00000000 '(53) 000/00000'
                     &b00000000 '(54) 000/00000'
                     &b00000000 '(55) 000/00000 -----------------------------------------'
                     &b00000000 '(56) 000/00000 empty place for character build data/ read from DD-ram address &h0f'
                     &b00000000 '(57) 000/00000'                                                       *use put&h0f*'
                     &b00000000 '(58) 000/00000'
                     &b00000000 '(59) 000/00000'
                     &b00000000 '(60) 000/00000'
                     &b00000000 '(61) 000/00000'
                     &b00000000 '(62) 000/00000'
                     &b00000000 '(63) 000/00000 -----------------------------------------'
tabend
'************* ERROR MESSAGES **************'
