> Why does the following program not work?? It "works" for me. Why do you ask? Do you not get what you expected? Well, then your expectations weren't correct ... ;-) > > define x word[1] > put 0 > #start > x = -1 > print x > print x / 256 What do you get here? Without testing I'd expect the output 0. Because -1 divided by 256 is the same as 1 divided by 256 just with a minus sign in front. (Division does take the sign into account) 1/256 is 0 since we have an integer division and not float. -0 prints as 0. > print x mod 255 What do you get here? Without testing I'd expect the output -1. > print (x and &hff00) shr 8 Totally different operation unless x is positive. HTH Bye Achim |
