> Just an addendum as a result of my recent work: > I just found out that the SGN function in CControl 1 V2.0 does not work correctly. > When evaluating a positive number, for example SGN(5), the function replies (0) instead of (1). > I made a workaround with some IF THEN lines as shown below: > > 'ROUTINE ALS ERSATZ DER DEFEKTEN SGN-FUNKTION > 'in > #Signum_Funktion > IF C < 0 THEN GOTO Kleiner_Null > IF sw_Function1_Return = 0 THEN GOTO Gleich_Null > IF sw_Function1_Return > 0 THEN GOTO Groesser_Null > #Kleiner_Null > sw_Function1_Return = -1 > RETURN > #Gleich_Null > sw_Function1_Return = 0 > RETURN > #Groesser_Null > sw_Function1_Return = 1 > RETURN > > MaPi |
