 Print Befehle welcher Syntaxfehler ? Kategorie: Programmierung Basic (von Pohl - 6.11.2011 17:42)
Pohl nutzt:  CC1-M-Unit V1.1, C-Control 2
Hallo , ich weiss nicht woran es liegt. Kann mir vielleicht jemand helfen ? Ab Print ..... Gruss B.Pohl
' Definitonen *******************************************************
' Ports
'Define P1 Port[1]
'Define P2 Port[2]
Define P3 Port[3]
Define P4 Port[4]
Define P5 Port[5]
Define P6 Port[6]
Define K1 Port[7]
Define K2 Port[8]
Define F1 Port[9]
Define F2 Port[10]
Define F3 Port[11]
Define F4 Port[12]
Define Led1 Port[13]
Define Led2 Port[14]
Define Led3 Port[15]
Define Led4 Port[16]
Define A1 Ad[1]
Define A2 Ad[2]
Define A3 Ad[3]
Define A4 Ad[4]
Define T1 Ad[5]
Define T2 Ad[6]
'DEFINE U1 AD[7]
'DEFINE U2 AD[8]
'Variablen
Define Bit1 Bit[1]
Define Bit2 Bit[2]
Define Bit3 Bit[3]
Define Bit4 Bit[4]
Define Bit5 Bit[5]
Define Bit6 Bit[6]
Define Bit7 Bit[7]
Define Bit8 Bit[8]
Define B1 Byte
Define B2 Byte
Define B3 Byte
Define B4 Byte
Define B5 Byte
Define B6 Byte
Define B7 Byte
Define B8 Byte
Define W1 Word
Define W2 Word
Define W3 Word
Define W4 Word
Define W5 Word
Define W6 Word
Define W7 Word
Define W8 Word
' Start des Programms **********************************************************
#start
  B1 = 0
  If Rxd Then Get B1
  If B1 = 0 Then Goto Step
  ' if b1 <> 0 then alles ausgeben und eventuell b1 interpretieren
  Print ">"
  Print "bit=" , Bit1 , Bit2 , Bit3 , Bit4 , Bit5 , Bit6 , Bit7 , Bit8
  Print "b=" , B1 , B2 , B3 , B4 , B5 , B6 , B7 , B8
  Print "w=" , W1 , W2 , W3 , W4 , W5 , W6 , W7 , W8
  Print "P=" , P1 , P2 , P3 , P4 , P5 , P6
  Print "A=" , A1 , A2 , A3 , A4
  Print "T=" , T1 , T2
  Print "K=" , K1 , K2
  Print "F=" , F1 , F2 , F3 , F4
  Print "LED=" , Led1 , Led2 , Led3 , Led4
' Hier kann man b1 interpretieren
#interpret
' Hier kommt das SPS Programm
#step
  If F1 = -1 Then Led1 = 0
  If F2 = -1 Then Led2 = 0
  If F3 = -1 Then Led3 = 0
  If F4 = -1 Then Led4 = 0
  If F1 = 0 Then Led1 = 1
  If F2 = 0 Then Led2 = 1
  If F3 = 0 Then Led3 = 1
  If F4 = 0 Then Led4 = 1
  Goto Start
' Ende des Programms ***********************************************************
#ende
  End
Re: Print Befehle welcher Syntaxfehler ? (von gerdl - 7.11.2011 11:56)
    Re: Print Befehle welcher Syntaxfehler ? (von Pohl - 7.11.2011 12:57)
Re: Print Befehle welcher Syntaxfehler ? (von Jens - 6.11.2011 18:44)
    Re: Print Befehle welcher Syntaxfehler ? (von Pohl - 7.11.2011 9:37)
        Re: Print Befehle welcher Syntaxfehler ? (von Jens - 7.11.2011 18:14)
Re: Print Befehle welcher Syntaxfehler ? (von MaPi - 6.11.2011 18:19)
    Re: Print Befehle welcher Syntaxfehler ? (von Pohl - 7.11.2011 9:39)
        Re: Print Befehle welcher Syntaxfehler ? (von MaPi - 7.11.2011 18:19)
            Re: Print Befehle welcher Syntaxfehler ? (von Pohl - 8.11.2011 10:44)
                Re: Print Befehle welcher Syntaxfehler ? (von MaPi - 8.11.2011 18:42)
                    Re: Print Befehle welcher Syntaxfehler ? (von MaPi - 8.11.2011 18:43)
                Re: Print Befehle welcher Syntaxfehler ? (von MaPi - 8.11.2011 18:32)
                Re: Print Befehle welcher Syntaxfehler ? (von MaPi - 8.11.2011 18:29)
                    Re: Print Befehle welcher Syntaxfehler ? (von MaPi - 8.11.2011 19:39)
