> > Bug 2? > > Using a terminal program try the program below: > > > > #start > > print”HELLO” > > print”HELLO” > > pause 200 > > end > > > > The terminal will give: > > > > ELLO > > HELLO > > > > Where is the H? > > This could be probably not a bug of the controller but a "bug" of the seriell interface. No, sorry - this is indeed a known bug of the unit. It was already mentioned in the forum. Until that time I worked my ass off to check my seriell interface. All in vane. A dummy "put 0" is a workaround that eases the matter. I hope that problem is solved in the next revision. Henrik Meine Homepage: http://www.henrik-reimers.de |
