'----------------------------------------------------------------------------------------------------' '***********************************************************************' '* WINDT SYSTEMS *' '* MAZE GAME v1.0 for CC1M2.01 with CC1AB2.0 *' '* H.J. WINDT *' '* 2004 *' '***********************************************************************' '----------------------------------------------------------------------------------------------------' 'FIND YOUR WAY OUT OF THE MAZE!!!!' 'USE THE KEYS TO MOVE.' 'KEY 2 = UP' 'KEY 4 = LEFT' 'KEY 6 = RIGHT' 'KEY 8 = DOWN' 'HAVE FUN!!' '----------------------------------------------------------------------------------------------------' '*************** INS and OUTS ***************' define db4 port[9] define db5 port[10] define db6 port[11] define db7 port[12] define rw port[13] define rs port[14] define en port[15] define lcd_light_off port[16] define in_key ad[8] '*******************************************' '**************** VARIABLES ****************' define data byte[1] define bit1 bit[1] define bit2 bit[2] define bit3 bit[3] define bit4 bit[4] define bit5 bit[5] define bit6 bit[6] define bit7 bit[7] define bit8 bit[8] define adr byte[2] define cmd byte[3] define dat byte[4] define area_build_data byte[6] define bottom_wall bit[41] define right_wall bit[42] define top_wall bit[43] define left_wall bit[44] define player_position byte[7] define last_player_position byte[8] define steps word[5] '*******************************************' '**************** CONSTANTS ****************' '*******************************************' '****************** SETUP ******************' gosub initialize_lcd beep 4,2,4 beep 4,2,4 lcd_light_off = 0 player_position = 0 '*******************************************' '***************** PROGRAM *****************' #start looktab maze, player_position, area_build_data gosub print_maze_on_display if player_position = 246 then goto is_out gosub get_player_direction goto start '*******************************************' '*************** SUBROUTINES ***************' #is_out pause 50 print"#CLR#"; print" YOU ARE OUT!!!"; print"#L201#"; print"IN "; print steps; print" STEPS"; print"#OFF#"; beep 1,10,4:beep 2,9,4:beep 3,8,4:beep 4,7,4:beep 5,6,4:beep 6,5,4:beep 7,4,4:beep 8,3,4:beep 9,2,4:beep 10,1,4 end #get_player_direction if in_key < 8 then goto get_player_direction if top_wall = 0 then if in_key > 45 and in_key < 55 then player_position = player_position - 16 if left_wall = 0 then if in_key > 77 and in_key < 87 then player_position = player_position - 1 if right_wall = 0 then if in_key > 109 and in_key < 119 then player_position = player_position + 1 if bottom_wall = 0 then if in_key > 142 and in_key < 152 then player_position = player_position + 16 #wait pause 10 if in_key > 8 then goto wait if last_player_position <> player_position then beep 4,2,4 if last_player_position <> player_position then steps = steps + 1 last_player_position = player_position return #print_maze_on_display print"#L101#"; if left_wall <> 0 then put&h0b else put&h0e if top_wall <> 0 then put&h0a else put&h0f if top_wall <> 0 then put&h0a else put&h0e if right_wall <> 0 then put&h09 else put&h0f print"Steps Taken:" print"#L201#"; if left_wall <> 0 then put&h0b else put&h0c if bottom_wall <> 0 then put&h08 else put&h0d if bottom_wall <> 0 then put&h08 else put&h0c if right_wall <> 0 then put&h09 else put&h0d print" "; print steps; return #command_to_lcd deact db7:deact db6:deact db5:deact db4:rw = 0:rs = 0:en = 0 data = &b00000000 or cmd shr 4:db7 = bit4:db6 = bit3:db5 = bit2:db4 = bit1:pulse en data = &b00000000 or (cmd - (cmd shr 4 shl 4)):db7 = bit4:db6 = bit3:db5 = bit2:db4 = bit1:pulse en return #data_to_CG_ram_lcd cmd = &b01000000 or adr : gosub command_to_lcd deact db7:deact db6:deact db5:deact db4:rw = 0:rs = 1:en = 0 data = &b00000000 or dat shr 4:db7 = bit4:db6 = bit3:db5 = bit2:db4 = bit1:pulse en data = &b00000000 or (dat - (dat shr 4 shl 4)):db7 = bit4:db6 = bit3:db5 = bit2:db4 = bit1:pulse en return #initialize_lcd print"#ON_LCD#";:print"#INIT#";:print"#CLR#"; #character_build for adr = 0 to 63 looktab characterbuild, adr, dat gosub data_to_CG_ram_lcd next return '*******************************************' '****************** DATA *******************' table characterbuild &b00000000 &b00000000 &b00000000 &b00000000 &b00000000 &b00000000 &b00011111 &b00011111 &b00011000 &b00011000 &b00011000 &b00011000 &b00011000 &b00011000 &b00011000 &b00011000 &b00011111 &b00011111 &b00000000 &b00000000 &b00000000 &b00000000 &b00000000 &b00000000 &b00000011 &b00000011 &b00000011 &b00000011 &b00000011 &b00000011 &b00000011 &b00000011 &b00000000 &b00000000 &b00000000 &b00000000 &b00000000 &b00000000 &b00000011 &b00000011 &b00000000 &b00000000 &b00000000 &b00000000 &b00000000 &b00000000 &b00011000 &b00011000 &b00000011 &b00000011 &b00000000 &b00000000 &b00000000 &b00000000 &b00000000 &b00000000 &b00011000 &b00011000 &b00000000 &b00000000 &b00000000 &b00000000 &b00000000 &b00000000 tabend table maze 12 5 5 4 5 5 6 12 5 5 5 5 5 5 5 6 10 13 6 10 12 5 3 10 13 5 5 5 4 5 5 3 10 14 10 10 10 12 5 0 5 4 4 5 0 4 4 6 8 1 3 10 10 10 13 3 15 10 8 7 10 9 3 10 10 13 5 3 10 10 12 5 5 3 8 6 8 5 5 2 10 14 12 5 3 10 10 12 5 5 3 10 10 13 6 10 9 0 1 5 5 3 10 10 12 6 15 10 9 6 10 11 14 10 12 4 5 6 10 10 10 8 5 3 12 3 10 14 10 10 10 10 13 3 10 10 9 1 5 5 1 7 10 10 10 10 11 8 5 5 3 9 5 5 5 5 5 6 10 10 8 1 5 2 12 4 5 5 7 13 4 5 5 2 8 2 10 12 7 11 11 10 13 5 5 5 1 5 7 10 10 10 10 8 4 5 5 1 5 5 4 5 5 5 5 0 3 10 10 10 8 5 5 5 5 5 2 14 12 5 5 1 7 11 10 10 9 5 5 5 4 7 10 9 1 5 5 5 5 6 11 9 5 5 5 7 0 13 1 5 5 5 5 5 5 3 tabend '*******************************************' |
