'----------------------------------------------------------------------------------------------------' '***********************************************************************' '* WINDT SYSTEMS *' '* COMPASS CMPS03 16 BIT BEARING READ v1.3 for CC1M2.01 with CC1AB2.0 *' '* H.J. WINDT *' '* 2004 *' '***********************************************************************' '----------------------------------------------------------------------------------------------------' 'This program reads the 16 bit bearing data from the MILFORD Magnetic Compass Module (CMPS03) #5-124 ' 'via the I2C bus and displays the data on the lcd as Bearing and Direction' 'Bearing range is from 0 to 3599, this represents 0º to 359.9º' 'Feel free to use and share this software!' '----------------------------------------------------------------------------------------------------' '*************** INS and OUTS ***************' define lcd_light_off port[16] '*******************************************' '**************** VARIABLES ****************' define config byte[1] define iic_error bit[7] define iic_high_byte byte[3] define iic_low_byte byte[4] define iic_word word[2] '*******************************************' '**************** CONSTANTS ****************' '*******************************************' '****************** SETUP ******************' print"#ON_LCD#"; print"#INIT#"; print"#CLR#"; print"#OFF#"; lcd_light_off = 0 '*******************************************' '***************** PROGRAM *****************' #start gosub compass_read print"#ON_LCD#"; print"#L101#"; print"Bearing = "; print iic_word / 10; put &h2e '.' print iic_word - (iic_word / 10 * 10); put &hdf 'º' print" "; print"#L201#"; print"Direct. = "; gosub print_direction print" "; print"#OFF#"; goto start '*******************************************' '*************** SUBROUTINES ***************' #compass_read print"#ON_IIC#"; print"#START#"; put &b11000000 'CMPS03 ADDRESS AND WRITE' put &b00000010 'CMPS03 START REGISTER FOR 16 BIT COMPASS DATA' print"#STOP#"; print"#START#"; put &b11000001 'CMPS03 ADDRESS AND READ' get iic_high_byte 'READ HIGH BYTE' get iic_low_byte 'READ LOW BYTE' print"#STOP#"; print"#OFF#"; gosub check_for_iic_error 'CHECK FOR I2C ERROR' if iic_error = 1 then goto compass_read if iic_word < 0 or iic_word > 3599 then goto compass_read 'CHECK FOR CMPS03 DATA ERROR' return #check_for_iic_error print"#ON_CONFIG#"; get config if iic_error = 0 then goto pass_iic_error_clear iic_error = 0 put config iic_error = 1 #pass_iic_error_clear print"#OFF#"; return #print_direction if iic_word > 112 then goto pass_n print"N"; return #pass_n if iic_word > 337 then goto pass_nne print"NNE"; return #pass_nne if iic_word > 562 then goto pass_ne print"NE "; return #pass_ne if iic_word > 787 then goto pass_ene print"ENE"; return #pass_ene if iic_word > 1012 then goto pass_e print"E"; return #pass_e if iic_word > 1237 then goto pass_ese print"ESE"; return #pass_ese if iic_word > 1462 then goto pass_se print"SE"; return #pass_se if iic_word > 1687 then goto pass_sse print"SSE"; return #pass_sse if iic_word > 1912 then goto pass_s print"S"; return #pass_s if iic_word > 2137 then goto pass_ssw print"SSW"; return #pass_ssw if iic_word > 2362 then goto pass_sw print"SW"; return #pass_sw if iic_word > 2587 then goto pass_wsw print"WSW"; return #pass_wsw if iic_word > 2812 then goto pass_w print"W"; return #pass_w if iic_word > 3037 then goto pass_wnw print"WNW"; return #pass_wnw if iic_word > 3262 then goto pass_nw print"NW"; return #pass_nw if iic_word > 3487 then goto pass_nnw print"NNW"; return #pass_nnw print"N"; return '*******************************************' '****************** DATA *******************' '*******************************************' |
