> Hello, > > hard to say what's wrong with THIS program, (I do not have the book [1]), but you can get addittional help and tips, when you check the documentation of M-Unit 2.0, even if you don't have it. It provides a port module (Conrad# 198848) where you can see in the documentation if you use the 8574 properly (pins etc.) > > Also there are demo programs available for the use of this module, so you could use this demos and replace the print# / i2c start / i2c stop - statements inside by subroutines (gosub) that do the same. So you see if your 8574 Hardware is responding properly. > > Carsten > > > Please, who can help me to program a PCF8574. What is wrong in the program given below. I like to turn a stepper connnected to P4-P7 (of the PCF8574) when a switch) connected to P3 is depressed. P0/P3 are connected with a pull-up to 5V . By pressing the switch P3 will be connected with a pull-up to 5 V > > > > define .......etc > > > > SDA=on > > SCL=on > > zaehler=&B00001000 > > > > #loop > > 'reading ON/OFF of P3 > > gosub start > > datenW=65 > > gosub I2C_write > > gosub I2C_read > > gosub Noack > > gosub Stop > > if datenR=&B00001111 then gosub motor else goto loop > > goto loop > > > > #motor > > zaehler =zaehler shl 1 > > gosub start > > datenW=64 > > gosub I2C_write > > datenW=Zaehler > > gosub I2C_write > > gosub stop > > if zaehler=&B10000000 then zaehler=&B00001000 > > return > > > > #start > > please refer to [1] > > > > #stop > > please refer to [1] > > > > #I2C_write > > please refer to [1] > > read instead of daten : datenW > > > > #I2C_read > > please refer to [1] > > read instead of daten: datenR > > > > #Ack > > please refer to [1] > > > > #Noack > > please refer to [1] > > > > [1] Messen, Steueren, Regeln mit dem C-Control/BASIC System von Kainka (page 163 u.w.) > > > > thank you very much > Hallo Carsten,, Thank you for your answer Question1 Regarding [1] : please refer to the answer I have given to Achim Questikn2 Next to other documentation I have also " studied " the documentation of the M -unit-2, but without any result Question3 It is not a hardware problem, as there is nothing wrong with the I2C-bus PCF8574. The problem is the software. If you replace the #loop by: #loop goto motor return then the stepper runs merrily. The problem in #loop is reading the position of the switch (ON or OFF) connected (in this case) to P3 of the PCF8574 I hope you can help me kind regards rien van harmelen Kind regards |
