Okay i interpretate your penetrant posting of your program as: "you want to have some reaction on posting your program" here it is: where can the sensor be bought? how much will it cost? can you translate it into german? sl > '----------------------------------------------------------------------------------------------------' > '***********************************************************************' > '* WINDT SYSTEMS *' > '* CMPS03 16 bit bearing read v1.0 for CCIMU1.1 with CCISB *' > '* H.J. WINDT *' > '* 2004 *' > '***********************************************************************' > '----------------------------------------------------------------------------------------------------' > 'This software, with the C-Control Main Unit 1.1 mounted on the C-Control starterboard,' > 'will read the 16 bit bearing from the compass CMPS03 and display the bearing on a terminal program.' > 'Port 15 will be used as the sda port for I2C communication.' > 'Port 16 will be used as the scl port for I2C Communication.' > 'For demonstration purpose use a terminal program like the one I found >>' > 'RS232 TERMINAL at www.b-kainka.de/pcmessfaq.htm' > 'Feel free to use and share this software.' > '----------------------------------------------------------------------------------------------------' > '*************** INS and OUTS **************' > define sda port[15] > define scl port[16] > '*******************************************' > '**************** VARIABLES ****************' > define i2c_byte byte[1] > define d7 bit[8] > define d0 bit[1] > define i2c_error bit[9] > > define i2c_high_byte byte[3] > define i2c_low_byte byte[4] > define i2c_word word[2] > define loop byte[5] > '*******************************************' > '**************** CONSTANTS ****************' > > '*******************************************' > '****************** SETUP ******************' > > '*******************************************' > '***************** PROGRAM *****************' > #start > gosub get_cmps03_bearing_word > print"Bearing = ";i2c_word > goto start > '*******************************************' > '*************** SUBROUTINES ***************' > #get_cmps03_bearing_word > i2c_error = 0 > > gosub start_i2c > > i2c_byte = &b11000000 'CMPS03 ADDRESS + WRITE' > for loop = 1 to 8 > sda = d7 > gosub scl_pulse > i2c_byte = i2c_byte shl 1 > next > gosub ack_i2c > > i2c_byte = 2 'CMPS03 REGISTER' > for loop = 1 to 8 > sda = d7 > gosub scl_pulse > i2c_byte = i2c_byte shl 1 > next > gosub ack_i2c > > gosub restart_i2c > > i2c_byte = &b11000001 'CMPS03 ADDRESS + READ' > for loop = 1 to 8 > sda = d7 > gosub scl_pulse > i2c_byte = i2c_byte shl 1 > next > gosub ack_i2c > > for loop = 1 to 8 'CMPS03 16 BIT BEARING HIGH BYTE' > d0 = sda > gosub scl_pulse > if loop < 8 then i2c_byte = i2c_byte shl 1 > next > i2c_high_byte = i2c_byte > deact sda > sda = 0 > gosub scl_pulse > deact sda > > for loop = 1 to 8 'CMPS03 16 BIT BEARING LOW BYTE' > d0 = sda > gosub scl_pulse > if loop < 8 then i2c_byte = i2c_byte shl 1 > next > i2c_low_byte = i2c_byte > deact sda > sda = 0 > gosub scl_pulse > > gosub stop_i2c > if i2c_error then goto get_cmps03_bearing_word > if i2c_word < 0 or i2c_word > 3599 then goto get_cmps03_bearing_word > return > > #start_i2c > sda = 0 > scl = 0 > return > > #restart_i2c > deact sda > deact scl > sda = 0 > scl = 0 > return > > #stop_i2c > deact scl > deact sda > return > > #scl_pulse > deact scl > #wait > if scl = 0 then goto wait > deact scl > scl = 0 > return > > #ack_i2c > deact sda > if sda <> 0 then i2c_error = 1 > goto scl_pulse > '*******************************************' > '****************** DATA *******************' > > '*******************************************' > > > |
