I have looked thru the pdf file of the RN-MOTOR and have written an example for you to try, let me know how it works out. Greetings, H.J. Windt '----------------------------------------------------------------------------------------------------' 'Try this example for the RN-MOTOR, look under *** I/O PORTS *** for the I2C connections.' 'You may want to adjust some variables to make the RN-MOTOR work with your motors!!' '----------------------------------------------------------------------------------------------------' '**************** I/O PORTS ****************' define sda port[4] define scl port[5] '*******************************************' '**************** VARIABLES ****************' define i2c_nack bit[1] define i2c_last bit[2] define i2c_nack_count byte[2] define i2c_byte byte[3] define i2c_out_bit bit[24] define i2c_in_bit bit[17] define loop byte[4] '*******************************************' '**************** CONSTANTS ****************' '*******************************************' '****************** SETUP ******************' print"#ON_CONFIG#"; : put &b1000 : print"#OFF#"; '*******************************************' '***************** PROGRAM *****************' #start #set_motor_amps gosub start_i2c i2c_byte = &h56 : gosub write_byte_i2c i2c_byte = 10 : gosub write_byte_i2c i2c_byte = 1 : gosub write_byte_i2c i2c_byte = 2 : gosub write_byte_i2c i2c_byte = 190 : gosub write_byte_i2c i2c_byte = 255 : gosub write_byte_i2c gosub stop_i2c if i2c_nack_count > 18 then goto no_ack_from_i2c_device if i2c_nack then goto set_motor_amps #set_mode gosub start_i2c i2c_byte = &h56 : gosub write_byte_i2c i2c_byte = 10 : gosub write_byte_i2c i2c_byte = 14 : gosub write_byte_i2c i2c_byte = 0 : gosub write_byte_i2c i2c_byte = 255 : gosub write_byte_i2c i2c_byte = 255 : gosub write_byte_i2c gosub stop_i2c if i2c_nack_count > 18 then goto no_ack_from_i2c_device if i2c_nack then goto set_mode #switch_motor_on gosub start_i2c i2c_byte = &h56 : gosub write_byte_i2c i2c_byte = 10 : gosub write_byte_i2c i2c_byte = 10 : gosub write_byte_i2c i2c_byte = 2 : gosub write_byte_i2c i2c_byte = 255 : gosub write_byte_i2c i2c_byte = 255 : gosub write_byte_i2c gosub stop_i2c if i2c_nack_count > 18 then goto no_ack_from_i2c_device if i2c_nack then goto switch_motor_on #set_motor_direction gosub start_i2c i2c_byte = &h56 : gosub write_byte_i2c i2c_byte = 10 : gosub write_byte_i2c i2c_byte = 4 : gosub write_byte_i2c i2c_byte = 2 : gosub write_byte_i2c i2c_byte = 1 : gosub write_byte_i2c i2c_byte = 255 : gosub write_byte_i2c gosub stop_i2c if i2c_nack_count > 18 then goto no_ack_from_i2c_device if i2c_nack then goto set_motor_direction #set_motor_speed gosub start_i2c i2c_byte = &h56 : gosub write_byte_i2c i2c_byte = 10 : gosub write_byte_i2c i2c_byte = 8 : gosub write_byte_i2c i2c_byte = 2 : gosub write_byte_i2c i2c_byte = 200 : gosub write_byte_i2c i2c_byte = 255 : gosub write_byte_i2c gosub stop_i2c if i2c_nack_count > 18 then goto no_ack_from_i2c_device if i2c_nack then goto set_motor_speed #motor_endless_loop gosub start_i2c i2c_byte = &h56 : gosub write_byte_i2c i2c_byte = 10 : gosub write_byte_i2c i2c_byte = 6 : gosub write_byte_i2c i2c_byte = 2 : gosub write_byte_i2c i2c_byte = 255 : gosub write_byte_i2c i2c_byte = 255 : gosub write_byte_i2c gosub stop_i2c if i2c_nack_count > 18 then goto no_ack_from_i2c_device if i2c_nack then goto motor_endless_loop end '*******************************************' '*************** SUBROUTINES ***************' #start_i2c sda = 0 : scl = 0 return #stop_i2c sda = 0 : deact scl : deact sda return #write_byte_i2c for loop = 1 to 8 sda = i2c_out_bit deact scl #write_byte_i2c_clock_stretch if not scl then goto write_byte_i2c_clock_stretch scl = 0 i2c_byte = i2c_byte shl 1 next deact sda deact scl #write_byte_i2c_ack_clock_stretch if not scl then goto write_byte_i2c_ack_clock_stretch i2c_nack = sda scl = 0 if i2c_nack then goto i2c_error i2c_nack_count = 0 return #i2c_error i2c_nack_count = i2c_nack_count + 1 goto stop_i2c '*******************************************' '******* INITIALIZATION SUBROUTINES ********' '*******************************************' '****************** DATA *******************' '*******************************************' '************* ERROR MESSAGES **************' #no_ack_from_i2c_device print"**************************" print"* No ACK from I2C device *" print"**************************" pause 50 goto no_ack_from_i2c_device '*******************************************' > > > Hallo, > > ich versuche seit Tagen die Schrittmotorsteuerung RN-Motor über den I2C-Bus einer C-Control-1 M-Unit V2.0 anzusteuern und bekomme es einfach nicht hin. Hat vielleicht jemand das Problem schon gelöst und wäre bereit mich vor der Verzweiflung zu retten? > > Vielen Dank im Voraus für die Hilfe > > |
