Hello Hans, The CF-Module sends an answer to each command (OK or ERROR). I'm not sure, but possibly the C-Control sends a new command while the CF-Module is sending an answer, and so the CF-Module is not ready to receive a new command. > Bedankt Mario > > Ik heb je voorstel uitgeprobeerd maar het werkt jammer genoeg niet > I have tried out your proposal but it works unfortunately not > I have now simplified it > > AND > Now the data is coming direct from the C-control M-Unit 2.0 PIN 52 instead of the IC RS232 > and that works > > Now there is made a TEXT file test A.txt > > But unfortunately there is no data written > > We are nearly there, wat can be possibly wrong > > print "at+create testA.txt" 'Maakt een file testA.txt. > pause 150 '3 sec. > > #start > Print "at+datastream " ' To Send Data > PAUSE 150 > PRINT "DIT IS EEN TEST" > PRINT "Alles wat hier staat moet zichtbaar zijn" > PAUSE 25 'pause 0,5 sec > PRINT "+" 'Stop recording > PAUSE 25 > PRINT "+" 'Stop recording > PAUSE 25 > PRINT "+" 'Stop recording > pause 25 > > END > |
