 Nokia 3310 LCD 84x48 graphical display works fine Kategorie: Hardware (von Stefan Op de Beek - 4.01.2006 0:27)
Stefan Op de Beek nutzt:  CC1-Station V2.0
I connected a Nokia 3310 LCD display to the C-Control. I had to convert 5 to 3 V using a LM317 and a 74HC245. The display is quite dumb in terms of characters etc. It is just a graphical display and character sets must be loaded in the microcontroller itself. The display is controlled using SPI protocol. Quite simple: data is clocked in to the data input each high->low cycle of the clock. As a demonstration I donwloaded a bitmap on the display as can be seen on picture.
For your interest, the source code:
'------ I/O PORTS ---------
' 1 vdd
' 2 sclk
' 3 sdin
' 4 d/c
' 5 sce
' 6 gnd
' 7 vout
' 8 res
define nok_sclk port[13]
define nok_sda port[12]
define nok_dc port[11]
define nok_cs port[10]
define nok_res port[9]
define i as byte
define row as byte
define column as byte
define iloop as byte
define oloop as byte
define tmp as byte
define tmp2 as byte
define x as word
define val as byte
goto main
'------ SHOW A HEX NIBBLE -------------------------
FUNCTION HEXNIBBLE(TEMP as byte)
if TEMP<10 then
put (TEMP+48)
ELSE
put (TEMP+55)
END IF
END FUNCTION
'--   SHOW CONTENT OF VAL AS HEX VALUE           -
FUNCTION SHOW_HEX(VAL as byte)
define TEMP as byte
TEMP=VAL/16
HEXNIBBLE(TEMP)
TEMP=VAL MOD 16
HEXNIBBLE(TEMP)
END FUNCTION
FUNCTION DELAY (DEL as byte)
for oloop=0 to DEL '10ms steps
for iloop=1 to 200
NEXT
NEXT
END FUNCTION
function NLCD_Write (data as byte, mode as bit)
        put data
          ' Pull nok_dc true or false depending on mode
          if (mode) then
             nok_dc = true
          else
             nok_dc = false
          end if
          nok_cs = false
          ' Clock in 8 bits of data
          for i = 1 to 8
              nok_sclk = false
              if  (data and 80h) = 0 then
                 nok_sda = false
              else
                  nok_sda = true
              end if
              nok_sclk = true
              data = data shl 1
          next i
          nok_cs = true
End Function
function NLCD_GotoXY (xnokia as byte, ynokia as byte)
          NLCD_Write( 40h or ( ynokia and 7h ), false)
          NLCD_Write( 80h or ( xnokia and 7fh ), false)
end function
function NLCD_Clear()
'  Data bit is false
        nok_sda = false
          '  Data mode
          nok_dc = true
          nok_cs = false
          for row= 1 to 6
              ' 6 rows
              for column = 1 to 84
                  ' 84 columns or "pages"
                  for i=1 to 8
                      ' Clock for the 8 bits of the "page"
                      nok_sclk = false
                      nok_sclk = true
                  next i
              next column
          next row
end function
function NLCD_Init()
          ' Set initial status of LCD pins
          nok_sclk = false
          nok_sda = false
          nok_dc = false
          nok_cs = false
          nok_res = false
          ' Toggle LCD Reset
          DELAY(1)
          nok_res = false
          DELAY(25)
          nok_res = true
          nok_cs = true
          ';; Extended commands
          NLCD_Write (21h, false)
          ';; LCD Vop
          NLCD_Write (c5h, false)
            ';; Temp coef
          NLCD_Write (6h, false)
           ';; LCD Bias 1:48
          NLCD_Write (13h, false)
          ';; Standard commands
          NLCD_Write (20h, false)
           ';; Normal Mode
          NLCD_Write (0ch, false)
          ' Clear and position at top of LCD
          NLCD_Clear();
          NLCD_GotoXY(0,0);
end function
#main
NLCD_Init()
' NLCD_GotoXY (0,0)
FOR x = 1 TO 504
   val = Looktab(bmp_table,x)
   NLCD_Write(val,true)
next x
end
Table bmp_table
 00 00 00 00 00h F8h F8h 60h 80h F8h F8h 00h
C0h E0h 20h 20h E0h C0h 00h F8h
F8h 80h C0h 60h 20h 00h E8h E8h
00h 40h A0h A0h E0h C0h 00h 00h
00h 00h 10h 18h 48h F8h B0h 00h
10h 18h 48h F8h B0h 00h 60h 30h
F8h F8h 00h 00h F0h F8h 08h F8h
F0h 00h 00h 00h 00h F8h F8h 00h
00h 00h 00h 00h E0h F0h 18h 08h
08h 18h 10h 00h F8h F8h 08h 08h
F8h F0h 00h 00h
00h 07h 07h 00h 01h 07h 07h 00h
03h 07h 04h 04h 07h 03h 00h 07h
07h 01h 03h 87h 84h 80h 07h 07h
00h 03h 07h 04h 07h 07h 80h 80h
80h 00h 02h 06h 04h 07h 03h 00h
02h 06h 04h 07h 03h 00h 00h 80h
07h 07h 00h 00h 03h 07h 04h 07h
03h 00h 00h 00h 80h 07h 07h 04h
04h 84h 04h 00h 01h 03h 06h 84h
04h 06h 82h 80h 87h 07h 04h 04h
07h 03h 00h 00h
00h 00h 3Ch 42h 42h 42h 3Ch 00h
7Eh 02h 02h 02h 7Ch 00h 00h 00h
00h 1Eh 21h 40h 40h 40h 21h 00h
10h 10h 10h 00h 1Eh 21h 40h 40h
40h 21h 00h 3Ch 42h 42h 42h 3Ch
00h 7Eh 02h 02h 02h 7Ch 02h 7Fh
42h 00h 7Eh 04h 02h 00h 3Ch 42h
42h 42h 3Ch 00h 7Fh 00h 00h 00h
00h 7Fh 03h 1Ch 60h 1Ch 03h 7Fh
00h 41h 60h 50h 48h 47h 00h 00h
00h 00h 00h 00h
01h 01h FFh 00h C0h 70h 18h 08h
08h 18h 30h E0h 80h 00h 00h 00h
00h 00h 00h 00h 00h 00h 00h 00h
00h 00h 00h 00h 80h 80h 80h 80h
00h 00h 00h 00h
01h 01h FFh 1Eh 03h 00h 00h 00h
00h 00h 00h 00h 07h 1Ch F0h 80h
00h 00h 00h 00h 00h 00h 00h 80h
E0h 38h 0Eh 03h 01h 00h 00h 00h
00h 01h 01h 06h 18h 70h C0h 80h
00h 00h 80h F0h 10h 18h 08h 08h
18h 10h 60h 40h 00h 00h 00h 00h
80h 40h 40h 40h 40h 80h 00h 00h
80h 40h 40h 40h 80h 00h 00h 00h
00h 00h 00h C0h 00h C0h 40h 40h
40h 40h 80h 00h
81h 81h FFh 80h 80h 80h 80h 80h
80h 80h E0h 80h 80h 80h 80h 83h
82h 82h E6h 84h 86h 82h 81h 81h
80h 80h E0h 80h 80h 80h 80h 80h
80h 80h E0h 80h 80h 80h 80h 81h
81h 81h E0h 80h 80h 80h 80h 80h
80h 80h E0h 80h 80h 80h 00h 00h
11h 22h 22h 24h 24h 18h 00h 0Fh
End Table
Re: Nokia 3310 LCD 84x48 graphical display works fine (von Stefan Tappertzhofen - 6.01.2006 22:32)
    Re: Nokia 3310 LCD 84x48 graphical display works fine (von Stefan Op de Beek - 8.01.2006 0:38)
Re: Nokia 3310 LCD 84x48 graphical display works fine (von Carsten - 4.01.2006 9:35)
    Re: Nokia 3310 LCD 84x48 graphical display works fine (von Stefan Op de Beek - 6.01.2006 9:55)
