Besten Dank für die Hilfe. Michael > Hello, > Thanks Achim, I’ll be the first to admit that you are correct! ;) > Your idea also gave me a new idea, have a look. > It looks a lot “cleaner” this way. > Thanks again, > H.J. Windt > > define nr byte[1] > define temp byte[2] > define variable word[2] > > for nr = 0 to 5 > looktab cheksum, nr, variable > gosub print_hex > next > end > > #print_hex > put &h26 : put &h68 > temp = (variable and 61440) shr 12 : if temp < 10 then put temp + &h30 else put temp + &h37 > temp = (variable and 3840) shr 8 : if temp < 10 then put temp + &h30 else put temp + &h37 > temp = (variable and 240) shr 4 : if temp < 10 then put temp + &h30 else put temp + &h37 > temp = (variable and 15) : if temp < 10 then put temp + &h30 else put temp + &h37 > print"" > return > > Table cheksum &H64 &H65 &H66 &H67 &HFFFF &hA > tabend |
