Hello, Thank you very much for warning me about this! The problem was not with the variables temp_in or temp_out but with the way they are displayed. I guess I missed this while testing my example. Here is the corrected version, v1.4 Let me know how it works out. Greetings, H.J. Windt '* 2xDS1621 v1.4*' '**************** I/O PORTS ****************' define lcd_backlight_off port[16] '*******************************************' '**************** VARIABLES ****************' define configuration byte[1] define iic_nack bit[7] define ds1621_in_error bit[9] define ds1621_out_error bit[10] define iic_nack_count byte[3] define iic_byte byte[4] define ds1621_status byte[5] define loop byte[6] define temp_in word[4] define temp_out word[5] '*******************************************' '**************** CONSTANTS ****************' define ds1621_in_iic_address &h90 define ds1621_out_iic_address &h92 '*******************************************' '****************** SETUP ******************' put 0:print"#ON_LCD#";:print"#INIT#";:print"#CLR#";:lcd_backlight_off = 0:print"#OFF#"; '*******************************************' '***************** PROGRAM *****************' #start gosub get_ds1621_temperature print"#ON_LCD#"; print"#L101#";:print"T in = "; if temp_in < 0 then print"-"; print abs(temp_in/10);",";abs(temp_in-temp_in/10*10);:put&hdf:print"C "; print"#L108#";:if ds1621_in_error <> 0 then print"IIC Error "; print"#L201#";:print"Tout = "; if temp_out < 0 then print"-"; print abs(temp_out/10);",";abs(temp_out-temp_out/10*10);:put&hdf:print"C "; print"#L208#";:if ds1621_out_error <> 0 then print"IIC Error "; print"#OFF#"; goto start '*******************************************' '*************** SUBROUTINES ***************' #get_ds1621_temperature ds1621_in_error = 0 ds1621_out_error = 0 for loop = 1 to 2 #ds1621_start_convert print"#ON_IIC#"; print"#START#"; gosub ds1621_write_address put &hee print"#STOP#"; print"#OFF#"; gosub check_iic_nack if iic_nack_count > 6 then goto no_ack_from_ds1621 if iic_nack then goto ds1621_start_convert #ds1621_check_conversion_done print"#ON_IIC#"; print"#START#"; gosub ds1621_write_address put &hac print"#STOP#"; print"#OFF#"; gosub check_iic_nack if iic_nack then goto ds1621_pass_check_conversion_done print"#ON_IIC#"; print"#START#"; gosub ds1621_read_address get ds1621_status print"#STOP#"; print"#OFF#"; gosub check_iic_nack #ds1621_pass_check_conversion_done if iic_nack_count > 9 then goto no_ack_from_ds1621 if iic_nack then goto ds1621_check_conversion_done if (ds1621_status and 1) = 1 then if (ds1621_status and 128) = 0 then goto ds1621_check_conversion_done #ds1621_read_temp print"#ON_IIC#"; print"#START#"; gosub ds1621_write_address put &haa print"#STOP#"; print"#OFF#"; gosub check_iic_nack if iic_nack then goto pass_ds1621_read_temp print"#ON_IIC#"; print"#START#"; gosub ds1621_read_address get iic_byte if loop = 1 then if iic_byte > 127 then temp_in = (&hff00 + iic_byte) * 10 else temp_in = iic_byte * 10 if loop = 2 then if iic_byte > 127 then temp_out = (&hff00 + iic_byte) * 10 else temp_out = iic_byte * 10 get iic_byte if loop = 1 then if (iic_byte and 128) = 128 then temp_in = temp_in + 5 if loop = 2 then if (iic_byte and 128) = 128 then temp_out = temp_out + 5 print"#STOP#"; print"#OFF#"; gosub check_iic_nack #pass_ds1621_read_temp if iic_nack_count > 9 then goto no_ack_from_ds1621 if iic_nack then goto ds1621_read_temp if temp_in = -600 then goto ds1621_start_convert if temp_out = -600 then goto ds1621_start_convert #pass_get_ds1621_temperature next return #ds1621_write_address if loop = 1 then put ds1621_in_iic_address if loop = 2 then put ds1621_out_iic_address return #ds1621_read_address if loop = 1 then put ds1621_in_iic_address + 1 if loop = 2 then put ds1621_out_iic_address + 1 return #check_iic_nack print"#ON_CONFIG#"; get configuration if not iic_nack then goto pass_iic_nack_clear iic_nack = 0 put configuration iic_nack = 1 iic_nack_count = iic_nack_count + 1 print"#OFF#"; return #pass_iic_nack_clear iic_nack_count = 0 print"#OFF#"; return '*******************************************' '******* INITIALIZATION SUBROUTINES ********' '*******************************************' '****************** DATA *******************' '*******************************************' '************* ERROR MESSAGES **************' #no_ack_from_ds1621 beep 1,1,1:beep 10,1,1:beep 1,1,1:beep 10,1,1 if loop = 1 then ds1621_in_error = 1 if loop = 2 then ds1621_out_error = 1 goto pass_get_ds1621_temperature '*******************************************' |
