Thanks H.J.W Maybe I make a mistake but the platina is acording to tek. can you see the mistake Klik here to see the drawing Max128 - Munit2 pin 5 - Port 10 pin 7 - Port 9 pin 6 - Min Adress pin 8 - Min Adress pin 10 - Min Adress Hans > Hello, > It seems to me that the MAX128 is responding. > If the MAX128 was not responding then you would not get “0” but “4095”. > You should check your connections and read the datasheet again and make sure that you didn’t forget anything, especially the analog part of the MAX128. > Greetings, > H.J.W. |
