I think that I may have found 2 more bugs in the CC1M2.01 system. The example programs will demonstrate the bugs. Bug 1? Try the program below: #start beep 4,2,4 jump #jump_back pause 300 end #jump beep 10,2,4 jump_back The compiler does not give any errors and the program works perfectly but in lines 3 and 9 I forgot a goto. Bug 2? Using a terminal program try the program below: #start print”HELLO” print”HELLO” pause 200 end The terminal will give: ELLO HELLO Where is the H? Are these 2 more bugs in the CC1M2.01 or am I doing something wrong? Yours truly H.J. Windt |
