'----------------------------------------------------------------------------------------------------' '***********************************************************************' '* WINDT SYSTEMS *' '* 64 BYTES EXTRA VARIABLE RAM v1.4 for CC1M2.01 with CC1AB2.0 *' '* H.J. WINDT *' '* 2004 *' '***********************************************************************' '----------------------------------------------------------------------------------------------------' 'This program demonstrates storing variables in the 64 bytes of CG RAM located in the LCD mounted' 'on the Application Board 2.0' 'Writing to or reading from the CG RAM will NOT disturb the characters displayed on the LCD' 'in any way because displayed characters are stored in the DD RAM of the LCD.' 'CG RAM is usually used by the programmer to create his or her own characters,' '(C)haracter (G)eneration, but can be used to store data.' 'So, if you need to store variables in a RAM and are not planning to create you own characters then' 'feel free to use this software!!' 'For demonstration purpose use a terminal program like the one I found >>' 'RS232 TERMINAL at www.b-kainka.de/pcmessfaq.htm' '' 'NEW NEW NEW NEW:' 'Safety built into the subroutines' 'Subroutines for reading or writing bits, bytes and words to CG RAM' 'Bit addressing = 1 to 512' 'Byte addressing = 1 to 64' 'Word addressing = 1 to 32' 'For reading a bit, byte or word from the CG RAM, address must contain the address number, then just gosub to' 'read_bit_from_cg_ram_lcd or read_byte_from_cg_ram_lcd or read_word_from_cg_ram_lcd and the variable will be' 'returned in data' 'For writing a bit, byte or word to the CG RAM, address must contain the address number and data the variable,' 'then just gosub to write_bit_to_cg_ram_lcd or write_byte_to_cg_ram_lcd or write_word_to_cg_ram_lcd and' 'the variable is saved' '----------------------------------------------------------------------------------------------------' '*************** INS and OUTS ***************' '-----port 2 lcd connections-----' define db4 port[9] 'databus 4' define db5 port[10] 'databus 5' define db6 port[11] 'databus 6' define db7 port[12] 'databus 7' define rw port[13] '0 = write to lcd display / 1 = read from lcd display' define rs port[14] '0 = command / 1 = data' define en port[15] '1 to 0 = enable' define lcd_light_off port[16] '(off)0 = light on / (on)1 = light off' '*******************************************' '**************** VARIABLES ****************' define port_data byte[1]'port_data / used for translating byte into bits and vice versa for I/O of port 2 (lcd port), -' define pd_bit1 bit[1] '- needed because of a bug in the CC1M2.01 system/ also used in other subroutines' define pd_bit2 bit[2] define pd_bit3 bit[3] define pd_bit4 bit[4] define pd_bit5 bit[5] define pd_bit6 bit[6] define pd_bit7 bit[7] define pd_bit8 bit[8] define cmd byte[2] 'command code for subroutines' define adr byte[3] 'address code for subroutines' define dat byte[4] 'data code for subroutines' define address word[3] 'address code from user' define data word[4] 'data code from or to user' define first_byte_of_data byte[7] define second_byte_of_data byte[8] define loop word[5] define number word[6] '*******************************************' '**************** CONSTANTS ****************' '*******************************************' '****************** SETUP ******************' print"#ON_LCD#";:print"#INIT#";:print"#CLR#";:print" 64 BYTE EXTRA ";:print"#L201#";:print" VARIABLE RAM! ";:print"#OFF#"; lcd_light_off = 0 beep 4,2,4: beep 4,2,4 '*******************************************' '***************** PROGRAM *****************' #start print" Enter (0 to write bit) (1 to read bit) (2 to write byte) (3 to read byte) (4 to write word) (5 to read word)" gosub input_number_via_232 if number < 0 or number > 5 then goto start on number goto write_bit, read_bit, write_byte, read_byte, write_word, read_word #write_bit print"Enter address (1 to 512)" gosub input_number_via_232 address = number print"Enter bit (0 or 1)" gosub input_number_via_232 data = number gosub write_bit_to_cg_ram_lcd print"BIT SAVED!" goto start #read_bit print"Enter address (1 to 512)" gosub input_number_via_232 address = number gosub read_bit_from_cg_ram_lcd print"Bit ";address;" = ";data goto start #write_byte print"Enter address (1 to 64)" gosub input_number_via_232 address = number print"Enter byte (0 to 255)" gosub input_number_via_232 data = number gosub write_byte_to_cg_ram_lcd print"BYTE SAVED!" goto start #read_byte print"Enter address (1 to 64)" gosub input_number_via_232 address = number gosub read_byte_from_cg_ram_lcd print"In address ";address;" data = ";data print" "; goto start #write_word print"Enter address (1 to 32)" gosub input_number_via_232 address = number print"Enter word (-32768 to 32767)" gosub input_number_via_232 data = number gosub write_word_to_cg_ram_lcd print"WORD SAVED!" goto start #read_word print"Enter address (1 to 32)" gosub input_number_via_232 address = number gosub read_word_from_cg_ram_lcd print "In address ";address;" data = ";data print" "; goto start '*******************************************' '*************** SUBROUTINES ***************' #input_number_via_232 number = 0 get data 'get 8 bit ascii code' if data = 13 then return 'look for ascii code for ENTER' if data = 45 then goto input_negative_dec 'look for ascii code for -' #input_positive_dec data = data - 48 'translate ascii code into decimal' if number <> 0 then number = number * 10 + data else number = data 'build number' get data 'get 8 bit ascii code' if data = 13 then return 'look for ascii code for ENTER' goto input_positive_dec #input_negative_dec get data 'get 8 bit ascii code' if data = 13 then number = number * -1 'look for ascii code for ENTER and make number negative if so' if data = 13 then return 'look for ascii code for ENTER' data = data - 48 'translate ascii code into decimal' if number <> 0 then number = number * 10 + data else number = data 'build number' goto input_negative_dec #write_bit_to_cg_ram_lcd adr = (address - 1) / 8 gosub data_from_CG_ram_lcd port_data = dat cmd = 0 for loop = 1 to address cmd = cmd + 1 if cmd = 9 then cmd = 1 next cmd = cmd - 1 on cmd gosub wbit1, wbit2, wbit3, wbit4, wbit5, wbit6, wbit7, wbit8 dat = port_data adr = (address - 1) / 8 goto data_to_CG_ram_lcd #wbit1 pd_bit1 = data return #wbit2 pd_bit2 = data return #wbit3 pd_bit3 = data return #wbit4 pd_bit4 = data return #wbit5 pd_bit5 = data return #wbit6 pd_bit6 = data return #wbit7 pd_bit7 = data return #wbit8 pd_bit8 = data return #read_bit_from_cg_ram_lcd adr = (address - 1) / 8 gosub data_from_CG_ram_lcd port_data = dat cmd = 0 for loop = 1 to address cmd = cmd + 1 if cmd = 9 then cmd = 1 next cmd = cmd - 1 on cmd goto rbit1, rbit2, rbit3, rbit4, rbit5, rbit6, rbit7, rbit8 #rbit1 data = abs(pd_bit1) return #rbit2 data = abs(pd_bit2) return #rbit3 data = abs(pd_bit3) return #rbit4 data = abs(pd_bit4) return #rbit5 data = abs(pd_bit5) return #rbit6 data = abs(pd_bit6) return #rbit7 data = abs(pd_bit7) return #rbit8 data = abs(pd_bit8) return #write_byte_to_cg_ram_lcd adr = address - 1 dat = data goto data_to_CG_ram_lcd #read_byte_from_cg_ram_lcd adr = address -1 gosub data_from_CG_ram_lcd data = dat return #write_word_to_cg_ram_lcd adr = (address * 2) - 2 dat = first_byte_of_data gosub data_to_CG_ram_lcd adr = adr + 1 dat = second_byte_of_data goto data_to_CG_ram_lcd #read_word_from_cg_ram_lcd adr = (address * 2) - 2 gosub data_from_CG_ram_lcd first_byte_of_data = dat adr = adr + 1 gosub data_from_CG_ram_lcd second_byte_of_data = dat return #command_to_lcd deact db7:deact db6:deact db5:deact db4:rw = 0:rs = 0:en = 0 'setup for transmitting command to lcd display' port_data = &b00000000 or cmd shr 4:db7 = pd_bit4:db6 = pd_bit3:db5 = pd_bit2:db4 = pd_bit1:pulse en 'HIGH NIBBLE command to lcd' port_data = &b00000000 or (cmd - (cmd shr 4 shl 4)):db7 = pd_bit4:db6 = pd_bit3:db5 = pd_bit2:db4 = pd_bit1:pulse en 'LOW NIBBLE command to lcd' return #data_to_CG_ram_lcd if adr < 0 then adr = 0 else if adr > 63 then adr = 63 cmd = &b01000000 or adr : gosub command_to_lcd deact db7:deact db6:deact db5:deact db4:rw = 0:rs = 1:en = 0 'setup for transmitting data to lcd display' port_data = &b00000000 or dat shr 4:db7 = pd_bit4:db6 = pd_bit3:db5 = pd_bit2:db4 = pd_bit1:pulse en 'HIGH NIBBLE data to lcd' port_data = &b00000000 or (dat - (dat shr 4 shl 4)):db7 = pd_bit4:db6 = pd_bit3:db5 = pd_bit2:db4 = pd_bit1:pulse en 'LOW NIBBLE data to lcd' return #data_from_CG_ram_lcd if adr < 0 then adr = 0 else if adr > 63 then adr = 63 cmd = &b01000000 or adr : gosub command_to_lcd deact db7 : deact db6 : deact db5 : deact db4:rw = 1:rs =1 : en = 1 'setup for reading data' pd_bit4 = db7:pd_bit3 = db6:pd_bit2 = db5:pd_bit1 = db4:port_data = port_data shl 4 'HIGH NIBBLE data from lcd' pulse en:pd_bit4 = db7:pd_bit3 = db6:pd_bit2 = db5:pd_bit1 = db4:en = 0 'LOW NIBBLE data from lcd' dat = port_data goto command_to_lcd '*******************************************' '****************** DATA *******************' '*******************************************' |
