 Re: Was macht Config-Register bei PullUp Bit 3? Kategorie: C-Control I V1.2/2.0 (von Windt H.J. - 12.02.2005 0:19)
 Als Antwort auf Re: Was macht Config-Register bei PullUp Bit 3? von Windt H.J. - 12.02.2005 0:09
sorry, this one is better.
Greetings,
H.J. Windt
'**************** VARIABLES ****************'
define configuration byte[1]
define servo_mode bit[1]
define counter1 bit[2]
define counter2 bit[3]
define pullup_resistors_port1 bit[4]
define pullup_resistors_port2 bit[5]
define dcf77_synchronization bit[6]
define i2c_communication_error bit[7]
define start_key bit[8]
'****************** SETUP ******************'
gosub set_configuration
'***************** PROGRAM *****************'
#start
end
'*************** SUBROUTINES ***************'
#set_configuration
print"#ON_CONFIG#"; 'setting up the configuration for the CCIUM2.01'
get configuration
servo_mode = 0 'change to 1 changes the 2 PWM-DAC ports (da[1], da[2]) into servo mode'
counter1 = 0 'change to 1 changes the FREQ1 port into a HIGH to LOW active counter, max frequency is about 32767Hz'
counter2 = 0 'change to 1 changes the FREQ2 port into a HIGH to LOW active counter, max frequency is about 32767Hz'
pullup_resistors_port1 = 0 'change to 1 activates the internal pullup resistors for byteport[1]'
pullup_resistors_port2 = 0 'change to 1 activates the internal pullup resistors for byteport[2]'
put configuration
print"#OFF#";
return
Re: Was macht Config-Register bei PullUp Bit 3? (von JanPeter - 12.02.2005 1:39)
