 Re: Was macht Config-Register bei PullUp Bit 3? Kategorie: C-Control I V1.2/2.0 (von JanPeter - 12.02.2005 1:39)
 Als Antwort auf Re: Was macht Config-Register bei PullUp Bit 3? von Windt H.J. - 12.02.2005 0:19
> sorry, this one is better.
> Greetings,
> H.J. Windt
> '**************** VARIABLES ****************'
> define configuration byte[1]
> define servo_mode bit[1]
> define counter1 bit[2]
> define counter2 bit[3]
> define pullup_resistors_port1 bit[4]
> define pullup_resistors_port2 bit[5]
> define dcf77_synchronization bit[6]
> define i2c_communication_error bit[7]
> define start_key bit[8]
> '****************** SETUP ******************'
> gosub set_configuration
> '***************** PROGRAM *****************'
> #start
> end
> '*************** SUBROUTINES ***************'
> #set_configuration
> print"#ON_CONFIG#"; 'setting up the configuration for the CCIUM2.01'
> get configuration
> servo_mode = 0 'change to 1 changes the 2 PWM-DAC ports (da[1], da[2]) into servo mode'
> counter1 = 0 'change to 1 changes the FREQ1 port into a HIGH to LOW active counter, max frequency is about 32767Hz'
> counter2 = 0 'change to 1 changes the FREQ2 port into a HIGH to LOW active counter, max frequency is about 32767Hz'
> pullup_resistors_port1 = 0 'change to 1 activates the internal pullup resistors for byteport[1]'
Das ist mein Problem , der interne Pullup wird nicht aktiviert.
Ich messe keine 5 Volt am Port ?????
> pullup_resistors_port2 = 0 'change to 1 activates the internal pullup resistors for byteport[2]'
> put configuration
> print"#OFF#";
> return
