 Re: CF card van Avisaro Kategorie: Programmierung Basic (von Windt H.J. - 22.11.2005 1:53)
 Als Antwort auf Re: CF card van Avisaro von Hans - 21.11.2005 23:07
Hello again,
I have changed the program, taking great care of where the “CARRIAGE RETURN” and “LINE FEED” are needed.
I don’t understand the 1st answer from Avisaro but I think it has something to do with the + + +, I have also changed this in the program.
Greetings,
H.J. Windt
'****************** SETUP ******************'
pause 200                                           'Just a pause of 4sec.'
put 0                                               'Needed because of a bug in the C-Control I v2.0 rs232'
print"at+create test.txt"                           'Create test.txt /with cr&lf'
pause 150                                           'Pause 3sec.'
pause 50                                            '*Subroutine must still be written for receiving OK or ERROR*'
print"at+close"                                     'Close test.txt /with cr&lf'
'***************** PROGRAM *****************'
#start
print"at+append test.txt"                           'Open test.txt for appending data /with cr&lf'
print"at+datastream"                                'Type of data is datastream /with cr&lf'
print"The quick brown fox jumps over the lazy dog." 'datastream /with cr&lf'
print"The Avisaro Compact Flash Box is GREAT!"      'datastream /with cr&lf'
print"Testend?";                                    'Last datastream /NO cr&lf'
pause 50                                            'Pause 1sec.'
put&h2b                                             '+ /NO cr&lf >> could also be print"+";??'
#end_loop
beep 4,2,4: beep 4,2,4
goto end_loop
Re: CF card van Avisaro (von Hans - 22.11.2005 21:44)
    Re: CF card van Avisaro (von Hans - 27.11.2005 14:05)
        Re: CF card van Avisaro (von Windt H.J. - 27.11.2005 16:05)
            Re: CF card van Avisaro (von Hans - 27.11.2005 19:00)
                Re: CF card van Avisaro (von Windt H.J. - 30.11.2005 15:32)
                    Re: CF card van Avisaro (von Windt H.J. - 30.11.2005 21:58)
                       Re: CF card van Avisaro (von Hans - 30.11.2005 22:35)
