Thank you very much I cant wait to try it out but first i have to buy a new memory card I keep you informed Hans > Hello again, > I have changed the program, taking great care of where the “CARRIAGE RETURN” and “LINE FEED” are needed. > I don’t understand the 1st answer from Avisaro but I think it has something to do with the + + +, I have also changed this in the program. > Greetings, > H.J. Windt > > '****************** SETUP ******************' > pause 200 'Just a pause of 4sec.' > put 0 'Needed because of a bug in the C-Control I v2.0 rs232' > print"at+create test.txt" 'Create test.txt /with cr&lf' > pause 150 'Pause 3sec.' > pause 50 '*Subroutine must still be written for receiving OK or ERROR*' > print"at+close" 'Close test.txt /with cr&lf' > pause 50 '*Subroutine must still be written for receiving OK or ERROR*' > '*******************************************' > '***************** PROGRAM *****************' > #start > print"at+append test.txt" 'Open test.txt for appending data /with cr&lf' > pause 50 '*Subroutine must still be written for receiving OK or ERROR*' > print"at+datastream" 'Type of data is datastream /with cr&lf' > pause 50 '*Subroutine must still be written for receiving OK or ERROR*' > print"The quick brown fox jumps over the lazy dog." 'datastream /with cr&lf' > print"The Avisaro Compact Flash Box is GREAT!" 'datastream /with cr&lf' > print"Testend?"; 'Last datastream /NO cr&lf' > pause 50 'Pause 1sec.' > put&h2b '+ /NO cr&lf >> could also be print"+";??' > pause 50 'Pause 1sec.' > put&h2b '+ /NO cr&lf >> could also be print"+";??' > pause 50 'Pause 1sec.' > put&h2b '+ /NO cr&lf >> could also be print"+";??' > pause 50 '*Subroutine must still be written for receiving OK or ERROR*' > #end_loop > beep 4,2,4: beep 4,2,4 > goto end_loop > '*******************************************' |
