 CCIUM2.0x OS Bug Roundup Kategorie: Verschiedenes (von Drifter - 13.06.2011 22:30)
Have I missed any bugs in the OS for CCIUM2.0x in the listing below?
* Input bug (v2,01) -> needs work around, is available.
* Byteport2 bug -> needs work around, is available.
* RS232 bug -> does not send the very  first byte over the rs232 port, write “put 0” at the beginning of the software, only needs to be executed once.
* Port glitch -> port = off / deact port / port = on : will create a glitch, with deact the port is pulled high through an external pull-up resister but the port = on after the deact will cause the port to momentarily go low (glitch) and then high again.
Re: CCIUM2.0x OS Bug Roundup (von MaPi - 15.06.2011 9:25)
    Addendum: SGN function does not work correctly (von MaPi - 19.06.2011 1:35)
        Re: Addendum: SGN function does not work correctly (von Windt H.J. - 20.06.2011 17:36)
            Re: Addendum: SGN function does not work correctly (von MaPi - 20.06.2011 21:57)
