Hello, please try to ask you question in a different forum especially made for CControl 1 V2.0. (-->http://www.tappertzhofen.eu/forum). Thank you, MaPi > Have I missed any bugs in the OS for CCIUM2.0x in the listing below? > > * Input bug (v2,01) -> needs work around, is available. > > * Byteport2 bug -> needs work around, is available. > > * RS232 bug -> does not send the very first byte over the rs232 port, write “put 0” at the beginning of the software, only needs to be executed once. > > * Port glitch -> port = off / deact port / port = on : will create a glitch, with deact the port is pulled high through an external pull-up resister but the port = on after the deact will cause the port to momentarily go low (glitch) and then high again. |
