Hello, I have been reading the documentation of the M3248. The power supply for this unit is 3,3V / ~100mA, the I/O pins are normal TTL 0/5V level. The RxD and TxD from the M3248 should be connected directly to the TxD and RxD of your C-Control. Are you using a C-Control I Unit M2.0 with an Application Board 2.0? You can find these connections on the Application Board 2.0 connectors J5 and J6. J5-3 is the TxD. J5-4 is the RxD. J6-1 is the TxD. J6-3 is the RxD. Greetings, H.J. Windt |
